Motor shakes
Old Jul 30, 2008 | 12:27 AM
yellowdemon327's Avatar
Default Motor shakes
Heres the prob: 2002 5.3liter with 94,000 miles on it, starts fine-engine is noisy due to lack of oil lubrication on initial start up. but mine is a little extra noisy. seems to idle fine, sometimes lopes a little bit. when i give it little gas and hold it(about 800-900rpms) the engine shakes like crazy-vibrates the whole body. above 1000rpms shaking goes away. ive heard about cam lobes getting worn, but i am not sure that this is the problem. this engine has had much abuse (a lot of high rpms), but always the finest maintainance(Mobile 1 full synthetic every 3000 miles religiously, fuel filter every oil change, new plugs and wires,etc).
Any help will be extremely appreciated. I would love to continue going to the track, but i do not know if i am just doing further damage to an exsisting problem.
Old Jul 30, 2008 | 11:55 AM
bump ttt
Old Jul 30, 2008 | 02:00 PM
anybody?
Old Jul 30, 2008 | 02:08 PM
shandy294's Avatar
Have you cleaned the t-body and IAC...maybe TPS going bad? You could get it scanned,too.
Old Jul 30, 2008 | 05:11 PM
viciousknid's Avatar
Where's the Beef?
It's a roller cam so i doubt the lobes are worn. How do you have low oil pressure tho? A tic at start up isn't usually low oil, its just piston slap until they get to operating temp.
Does it sound like it's missing when you hold the rpm's?
Just a few questions that may help your process in finding the answer.
Old Jul 30, 2008 | 07:28 PM
no, you're right i dont have low oil pressure- always excellent oil pressure
but when i hold it just at around those rpms, it feels like the motor comes out of balance..kinda like how a tire and rim will can vibrate at a certain mph, then become smooth at a higher speed. i wish i was a mechanic, cause this has me baffled, Haynes manual says it could be like 4-5 different things.
Also, thanks for the help guys
Old Jul 30, 2008 | 07:29 PM
not sure i can get it scanned if im using hp tuners....
Old Jul 30, 2008 | 10:37 PM
silveradol33's Avatar
Yea, u can its no different than stock for scanning.
Also, there is no ses light? is this all the time or once and a while, how long has it done it? could it be bad gas? or bad wire? bad plug? ect?
Old Jul 31, 2008 | 12:03 AM
its done it for a while now and maybe getting worse, no ses at all, maybe my tuner turned it off, but all your suggestions, except for bad gas make sense i guess.
Old Jul 31, 2008 | 09:24 AM
shandy294's Avatar
Does it do it in drive...for example you're at a stop sign at about 550 rpm and as you accelerate through 800-900 does it stumble or shake?
