more in dept 4l80e ??? (speartech)
Old Sep 30, 2003 | 05:50 PM
sleepersilverado's Avatar
Default more in dept 4l80e ??? (speartech)
ok so now we know the wireing is taken care of. but i have a fiew more ??
can you put a man valve body in one?
if so how do you make the converter lock and un lock?
can you put a trans brake on one?
Thanks in advance
i want a settup like my buddies car with a th350 reverse pat man valve body with a brake but do not want to loose overdrive or the converter lockup
Old Sep 30, 2003 | 06:12 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Default Re: more in dept 4l80e ??? (speartech)
The wiring and PCM programming is my end of it!
I'm not a tranny guy and I don't know the answers to your other questions.
Old Sep 30, 2003 | 06:21 PM
parish8's Avatar
single digit dreamer
if you do all that stuff you wont need the programing anymore. they make 4l80 trannys that just bolt in with no electronics that do what you want. they may not be able to lock up the converter though. the add i saw said something like "they just start to get comfortable at 900hp" do a search for 4l80e and the place a saw will come up
Old Sep 30, 2003 | 09:05 PM
i will do that. i was going to see what everone here knows but i will call around and see what all can be done. here is what i was thinking (in theory) dont know if it works like this have not played with edit yet and dont know much about the comp. but i was thinking that well i know you can turn off the stuff that operated the tranny in the comp but then this would not let the lock up part work either. so well what if you left it on and had the 80 with the comp stuff and man valvebody. then you would have to shift it but the computer would not be able to but i would think it would still be able to lock it up. or maybe you could put a verter lock up switch for like when you get on the highway.
i dont care much about around town but want to still be able to get on the hwy and get ok gas mileage. i mean if i did not care about that then i could get a th350 and it would go in easy and is alot cheaper (1500$) tranny and verter
sorry so long
Old Oct 1, 2003 | 07:47 AM
Scream's Avatar
MOOBIES Moderator
>>Raptor 4L80-E<<
calsdad
Jun 14, 2023 11:07 PM
RustyD
May 23, 2016 07:04 PM
AdaMax
May 16, 2016 11:35 PM
turbo6c3
Oct 5, 2015 06:11 PM
jscherbs
Sep 30, 2015 07:54 AM
