Misfire after headers
Old Aug 2, 2014 | 08:35 PM
Default Misfire after headers
Put knock sensors and headers and ory on my 04 Silverado today. After we put the knock sensors in I started the truck to make sure it run good after putting the intake back on and it was quiet and smooth. Put the headers and y pipe on with New gto plug wires. Started it and it run good and smooth for about 30 seconds and then got rough and comes up with multiple misfires. I took the plugs out while putting the headers on and made sure the wires were seated. Does it just need a tune. I left the back 02 sensors plugged up and just zip tied them up. Do I leave the or unplug them and take them off.
Old Aug 2, 2014 | 09:00 PM
FFDP's Avatar
Perhaps a plug has a crack in it, kinda hard to say.
I would remove them again and check them out. And make sure all injector connectors are plugged in all the way and no pins got bent.
Old Aug 2, 2014 | 09:03 PM
Go5.3tt06's Avatar
burn wire plug? happened to me before. what kind header are u using.
Old Aug 2, 2014 | 10:36 PM
terravast4's Avatar
yep.....you always burn one....or you dropped a spark plug and its cracked
Old Aug 3, 2014 | 02:43 AM
I'll grab a set of plugs and throw in it just incase and I'm using Pacesetters with gto plug wires. I do know it's not the plug wires
Tydriver
45
Oct 23, 2015 09:19 PM
Velocity1
Oct 12, 2015 10:39 PM
Superman09
Sep 25, 2015 05:55 AM
CammedZ71
11
Sep 9, 2015 02:05 PM
