Measurements of Cal-Speed 1 7/8" as requested
Old Mar 14, 2012 | 10:14 PM
BrutalSierra's Avatar
Default Measurements of Cal-Speed 1 7/8" as requested
Attached are the measurements of the "1 7/8" LT's and "3 1/2" ORY
@ Flange
Collector
DS collector to Y connection pipe(that make sense?)
Other side w/flared end
Y to cat back (flared)
Big end of Y
DS Y (flared)
PS Y (flared)
What are your
Opinions?
Old Mar 14, 2012 | 10:29 PM
GMCtrk's Avatar
The diameter of the primaries should be measured as the OD. It looks good though.
Old Mar 14, 2012 | 10:33 PM
The 4" mark is on the outside edge of the tube. Picture angle is deceiving.
Old Mar 15, 2012 | 09:57 AM
Sales2@Texas-speed's Avatar
Former Vendor
Agreed, tubing is measured OD (such as primaries).
Old Mar 15, 2012 | 12:51 PM
I knew that going into this, thats why the tape starts on the far outside of the tube. My calipers are MIA so the ole tape was all I had. Did i do something wrong?
Old Mar 15, 2012 | 04:41 PM
Former Vendor
What we mean is you have to measure primary tubing at the outside of the tube....bot right there at the flange. I guess you could wrap the tape around the primary, get an "accurate" read on that, and then divide by Pi to get the diameter.
Old Mar 15, 2012 | 04:50 PM
Yesterday would have been perfect for dividing by 3.14
Old Mar 15, 2012 | 04:53 PM
RibeiroBJJ's Avatar
Praise The Lowered
HE KNOWS.. You can see the o.d of the 1-7/8" pipe through the header flange where he is holding his tape as they are not welded on that side..Anywhere away from a bend is accurate..
Thanks for the pics...
Old Mar 15, 2012 | 08:48 PM
01silvy's Avatar
When will you be installing?
And what are you bolting that 3.5" y-pipe up to?
Old Mar 15, 2012 | 11:37 PM
I've gotta finish floors in my house 1st. Shoulda been done already but life happened.lol
The stock exhaust on 6.2's are 3.5" however I'm upgrading to 4"
