May Be Getting Free Headers
Got Edelbrock 65022 Headers Came In On A Customers Hummer Leadking... So We Replaced Em... And If The Customer Doesnt Want The Old Ones I Can Have Them...
The Only Problem Is The Passenger Side Header Collector Appears To Have A Small Leak Where The Main Pipes Meet... Will My Wire Feed Mig Welder Be Strong Enough Of A Weld For This? How Hard Should It Be To Repair? Or What Can I Use To Repair It??
Just clean it up real good, wire wheel brush and then wipe it down with acetone before welding, that is what I do. That is if you can get to it.... You might have to do it from the inside..
IT SAYS THERE CERAMIC COATED... THAT BEING THE CASE DO I HAVE TO WORRY ABOUT UNDERHOOD TEMPS?? I HEARD IT KEEPS TEMPS DOWN QUITE A BIT
DO I HAVE TO WORRY ABOUT MY PLUG WIRES??
