Max compression..Stock heads
Old Dec 25, 2005 | 08:40 PM
raisinkane's Avatar
Default Max compression..Stock heads
Just out of curiosity....
Stock 2003 5.3 heads, whats the most they could be shaved to up compression?
and/or thinner head gaskets.?
Does this do bad things with valve train geometry?
raisin
Old Dec 25, 2005 | 09:02 PM
litreddevil's Avatar
Banned
I Would Not Go More Than 50 Ths And Put A Shim Under The Rocker Bar The Same Amout U Shaved
Old Dec 26, 2005 | 01:55 AM
PappyDan's Avatar
Tribe Shaman
no one can really say how much can be safely shaved off before you do harm to the heads and turn them in to trash.
you need to take them to a machine shop and have them mic the heads.
this way the machine shop can tell you just how much can be removed and make you a set of balanced heads.
I have always said that no two heads are the same, the machine shop will tell you that you can shave 045 on one and 042 on the other and both heads will have the same compression on all cylinders.
Old Dec 26, 2005 | 03:00 PM
TarheelZ's Avatar
02SierraZ71 had .050 taken off his heads; don't know exactly how much compression he ended up with though. Just under a point, maybe? He did have some valve-train issues at first but now his truck runs like a scalded dog!
Old Dec 28, 2005 | 07:53 PM
ktmrider's Avatar
I think TarheelZ is right, every 0.010" is about 0.2 CR change. Valvetrain angle and pushrod length are gonna be your worst enemies. Someone makes altered length pushrods but no custom rocker arms yet.
Good octane gas and some tuning should show decent gains.
Oobray
Jun 13, 2022 03:38 AM
silverstreak07
Jun 28, 2016 06:29 PM
slowlsx
Aug 10, 2015 05:33 PM
05GMC4.8
Aug 7, 2015 09:55 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
