Marine injectors not fitting on NNBS intake
My problem too
I cut the tabs off the rails
Looked like this
Then I took my extra brackets from my tru-cool install a made brackets to hold the rails down.
The cross over tube will need to be tweaked to fit, but it will fit.. Just take your time and make all the right bends. Feel free to ask any question.
Looked like this
wow, thats wierd! I wondered what some guys were talking about when they were putting the old fuel rails on the nnbs intake from the nbs intake. They ground down the mounting tabs on the intake mani to get them to fit.
I know there is a fuel injection store online that sells injector extensions just for this purpose. Hint: think F. I. C.......
I think, let me double check that. Then you could use John's advice about clipping the injectors in first, adapters into the manifold, then the injector/rail assembly into the adapters. Fasten that bad boy down with stock bolts and be done with it. Only bad part about it is the adapter/extensions are around $12 a piece if I recall correctly.
Thanks, I just looked on their website, didn't see anything but I'll give them a call tomorrow. Would rather have injectors that fit than having to get extensions, but at this point I just want to get the truck running. If $12 an injector is what it takes I'll go for it. Swapped heads, cam, and intake awhile ago and the injectors are the one thing holding me up.
I think I miss-spoke on that earlier recommendation, and now I cannot find those spacers I was referring to. I know they're out there. But I did just so happen to find a FAST spacer kit that might work for you part# 146025-KIT. Hope that helps. They look to be about $30.xx for a set to on sum site that ends with mit.
