MAP sensor crazy?
Old Oct 8, 2009 | 07:40 PM
85irocinjected's Avatar
Default MAP sensor crazy?
So my 5.3 has issues starting and I just notice that with the engine OFF the MAP sensor is reading 97kPa. I have no codes and I triple checked my wiring and its good. Could this be a bad MAP sensor? What is it supposed to read with the engine off? I figured 0. Heck I even unplugged it and hptuners scanner is still showing 10kPa. Any ideas? Thanks in advance for any help.
Old Oct 8, 2009 | 07:42 PM
nonnieselman's Avatar
97 is right... its opposite from what you think.. 97 is the reading when theres no Vacuum in the intake..
should be around 40ish at idle.
Old Oct 8, 2009 | 08:32 PM
Well, Thanks. I guess I'm going to have to look else where for my starting issues. It will eventually start and sometimes run good, sometimes run like caca.
Old Oct 8, 2009 | 08:44 PM
is it a stock cam & stock tune?
Old Oct 10, 2009 | 07:35 PM
I figured it out...When I moved the pcm I forgot to hook up the ground wire for my coils on bank 2. Dumb a** on my part for not checking for spark first..haha "but it was running before I moved the computer..." <- stupid...
calsdad
Jun 14, 2023 11:07 PM
Pimpinpete
43
Dec 22, 2017 08:13 AM
gmcyukon
Oct 5, 2015 06:20 AM
KINGCYCLES
Oct 2, 2015 10:21 AM
WICK3DxGATA
Sep 24, 2015 06:56 PM
