map sensor ?
Old Jan 22, 2005 | 08:50 PM
litreddevil's Avatar
Banned
Originally Posted by v8
ok at 4k the map sensor is reading 29 and the maf is reading 15, but by the time you get to 62k map is still reading 29 and the maf is reading 39. is this correct or is the maf not doing its job down low??
I JUST WENT CHECK MINE @ 6619 RPM MAF 271.27 MAP IS @ 96
Old Jan 22, 2005 | 09:33 PM
ZDEN's Avatar
holy **** zden thats is way to high i would think, your maf should read way higher than the maf but then again on a 6000 hp motor your running there must need it lol
that is mass air flow in lbs/min and the map reading is kpa, the maximum map in our trucks is 105 kpa
Old Jan 23, 2005 | 09:47 AM
v8
17,16,15,14,13,12,11 Drvr
man i must have a weak maf and map sensor. put in new maf and it reads at 5700 37 and the map is going to 14.5. so as far as i know that is right with the map.
what are you reading your tables with zden and randy grabert???
Old Jan 23, 2005 | 11:55 AM
ZDEN's Avatar
hp tuners here. your maf reading looks right for lbs/min flow, but i don't know about the low map reading
Old Jan 23, 2005 | 05:18 PM
v8
well 02denali has hp tuners as well and he is seeing the same readings as i am 14.5 14.3 so i dont know lol
Old Jan 23, 2005 | 05:22 PM
one03sierra's Avatar
Formerly one92rs
Talking
the map reading on hptuners is 14.6 max. if ity is suppose to go higher then they need to fix there software. my maf is going to 44.0
Old Jan 23, 2005 | 09:03 PM
ZDEN's Avatar
i guess were not talking about the same thing, which pid are you logging with. I assume we are talking about manifold absolute pressure?
Old Jan 23, 2005 | 09:16 PM
v8
yes we are. i dont understand how you get 99 on your map hell you would blow head gaskets or something else up before it got that high.
Old Jan 23, 2005 | 09:18 PM
Formerly one92rs
Talking
yes it is the map sensor. it says (sae) whatever measurment that is.
Old Jan 23, 2005 | 09:32 PM
ZDEN's Avatar
i don't know how to post an image, but look in your editor under engine>airflow>primary ve vs. rpm vs. map(kpa)
