MAP problem
Old Nov 22, 2007 | 01:27 PM
pick1923's Avatar
Default MAP problem
I have a 2004 5.3L in a 58 Chevypickup. I got the engine running about a week ago but I am not getting a MAP signal. Does anyone out there have the pinouts for a 2004 computer so I can eliminate a wiring problem? Thanks Mark
Old Nov 23, 2007 | 06:43 PM
454SuperSport's Avatar
pin 48 connector 1, gray, 5 volt ref. to pin C on map sensor
pin 54 connector 1, orange/black, low ref. to pin A on map sensor
pin 32 connector 2, lt. green, map signal to pin B on map sensor
Old Nov 23, 2007 | 07:08 PM
pick1923's Avatar
I found almost the same info on a 2002 pcm, except for the 54 terminal was blk. I suspected that they only changed the wire color in 2004 and you confirmed it. The person who wired this harness used the wrong pins. Thanks for the info Mark
calsdad
Jun 14, 2023 11:07 PM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
