manifolds vs. shorties
Old Dec 21, 2006 | 02:02 PM
phatboy's Avatar
Default manifolds vs. shorties
i have ps shorties on my truck right now and im tired of the leaking on the passenger side. im sure this is were some of my mpg went. i am going to gasket match my manifolds and put them back on. My question is do you think i will lose any power doing this? truck is in sig.
Old Dec 21, 2006 | 03:53 PM
Stoichiometric's Avatar
I think that if you have 1.625" or larger shorties with a decent collector they will make a little more power than stock manifolds. So you may loose a little going back to the stock manifold.
Old Dec 21, 2006 | 09:33 PM
Might lose 5hp.
Jim
Old Dec 21, 2006 | 10:10 PM
KevinF56's Avatar
get some long tubes if you have the funds.
Old Dec 22, 2006 | 08:45 AM
phatboy's Avatar
i can deal with 5hp because im installing electric fans also, so 1 day ill invest in some long tubes.
Old Dec 22, 2006 | 08:52 AM
Go with the Pacesetters if your on a budget. They seem to be the best bang for the buck. About the same price for shorties.
Jim
Old Dec 22, 2006 | 12:48 PM
budhayes3's Avatar
PT's Slowest Truck
Where are they leaking from, where the header bolts to the head or to the y-pipe? If you're on a budget and can't afford new LT's, and it's where it bolts to the head, get some factory exhaust manifold gaskets and give that a shot. If they still leak, some high temp RTV should fix you up (the copper stuff that's orange). If it's leaking where the header bolts to the y-pipe, you could also try some hi-temp RTV and see if it works. When I installed my Gibson shorties, I used the copper RTV on the head to header gaskets and where the headers bolted to the y-pipe and had 5 years of service with no problems. They were still sealed perfectly when I removed them to upgrade to StainlessWorks LT's and catted y-pipe.
OHsixLS3
Nov 22, 2015 07:45 PM
turbo6c3
Oct 5, 2015 06:11 PM
JordanH
Oct 3, 2015 03:59 PM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
