Magnaflow not loud enough!
Old Feb 4, 2004 | 09:19 AM
  #21
BigTex's Avatar
For more sound from your existing magnaflow muffler, just cut off the tailpipes a few inches after the muffler. You can do that yourself. If you like it, get some turn down tips put on, or just leave it as-is. No one will see jup under there anyway.
If you want that Fbody sound, either remove or gut your catalytic converters, then change the muffler to a dynomax 3" in / out bullet racing muffler. The bullet will take a little of the edge off the sound, but will keep it plenty loud. Just dump it with turn downs at that point.
Old Feb 4, 2004 | 04:19 PM
  #22
2003Silvyrado's Avatar
I had this problem. I liked the magnaflows' sound but it wasn't loud enough. A few people recommended a Dynomax Bullet, so I had one put on.
It sounds, friekin, bad, ***.
Really great sound at idle, thundering sound on partial acceleration, and it basically roars at full throttle. Fortunately it doesn't really sound like open exhaust, and they've quieted down a bit after driving it a hundred or so miles(which is good because the pounding/thundering noise at part throttle was making my ears ache)
Everyone comments that it sounds like a 350 when they hear it. It really doesn't sound like a little 4.8 any more.
Old Feb 4, 2004 | 06:17 PM
  #23
gonzo 6.2's Avatar
Yes Jim
I cant be that far behind you on installs,time to rotates the tires must be time to try a new muffler.
Old Feb 5, 2004 | 09:45 AM
  #24
oxidizr's Avatar
Moderator / Sponsor
Originally Posted by gonzo 6.0
I should have stuck with my gut and went the biggest,Oxidizer recommend the one i did install,he wouldnt think so if he heard it.Also my fault was i went to a guy i like and gives the best deals.If i had gone to the more spendy guy that did my mandrel piped install he would have told me not to do it and would have recommened something different because he's been there done that on so many late models.I will see him on Thursday,it would have been cheaper in the long run.
Gonzo:
-----Original Message-----
Sent: Friday, January 23, 2004 11:00 AM
To: rwaitas@magnaflow.com
Subject: Re:
I sent you 2 emails this was the first i think. Here is a copy of the second one.
I didnt think you would mind responding to a magnaflow question.I have used several magnaflows in the past and I am looking to do something again.I will copy and past my sig from the Ls1 tech board.
2K 1/2 ton xcab 4x4 GMC 6.0 swap stage 1 6.0 heads .020 off,comp 212/218 522/529 114Lc longtubes,HD cats,HD exhaust grafted in,UPD,Ed Wright
I have dual 3" going in,what muffler are you using on the hummer? or the escalade?
Of these magnaflow PN do you have a recommendation?
12763
12762
12599
12398
12590
I am after flow and not noise or drone. Please advise.Thanks Gonzo 6.0
**** If I read this correctly you weer looking for "FLOW AND NOT NOISE OR DRONE"
I made my recommendation based upon your criteria of flow
this was my response:
12398 3" / dual 3" (internal perforated X) 5x8x24
12763 3" / dual 2.5" 7x7x24
12762 3" / dual 2.5" 7x7x30
12590 3" / dual 3" 5x11x22
12599 dual 3" / dual 3" (internal perforated X) 5x11x22
From what I can tell it seems you are going to be working with a 330-350 RWHP combo.
Are you looking to do dual in / single out, true duals or whatever works best?
I would stick with a dual 3" inlet muffler with at least a single 4" or dual 3" outlet for best flow. A dual 2.5" will flow the cfm however if noise is not an issue the 3"s will give you room to grow. I prefer the 5x8x24 with perforated internal x because it saves mass and space. I also prefer the sound/tone of this muffler with 6.0L and larger applications. The 5x11x22's are more for resonance control, but are much more bulky.
Richard Waitas
Engineering / Product Development Manager
MAGNAFLOW Performance Exhaust / CAR SOUND Exhaust Systems
Main: 1-800-990-0905 x 3309 Direct: 949-858-8121 Fax: 949-459-0452
23201 Antonio Parkway Rancho Santa Margarita, CA 92688
I believe I gave you the information to make your own decision and I really hope you were not bashing my recommendations based upon your decision. Maybe I misread your request but even still I recommended the 5x11x22 if you wanted resonance control.
Old Feb 5, 2004 | 09:48 AM
  #25
Is there even a muffler on the SLP loud mouth exhaust? I am seriously thinking about uuting off my muffler and putting a 3" in. 2 1\2 out y-pipe on and running it to the back w/tips. Any comments or sugesstions?
Old Feb 5, 2004 | 10:07 AM
  #26
BigTex's Avatar
Good to hear from you Ox.
How much does the 5x11x22 dual 3" in / out muffler drone in an extended cab? I've put off getting a muffler until last because I don't want the drone.
Would a multi-chambered muffler in combination with a straight through round magnaflow be an effective solution to drone? I'm thinking that the chambers for sound cancelation, and the round muffler to strip off the drone.
I'm personally willing to run multiple mufflers in series if I gain flow without adding the drone. I don't mine the aggressive sound on the outside, just not that 1800 rpm freeway stuff.
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
Rockrz
Sep 29, 2015 09:07 AM
bisqikss
Sep 27, 2015 09:40 PM
