LY6 issues... NEED HELP
Old Mar 19, 2017 | 01:35 AM
Wolftrk99's Avatar
Dont fry the starter running 24volts to it.. i dont think you have a pump issue just dont think youre cranking it long enough to get oil up to the pushrods especially with it not cranking at full speed, i have had times even after priming with new everything(pump, lifters, pushrods, bearings, etc) it still took a couple seconds for the lifters to pump up fully after it started up.
I know all about frustartion will builds!! I forgot an oil galley plug in the 6.0 in my 99, the first time i fired it up i lost about 4 qts of oil in about 3 seconds!!
Old Mar 19, 2017 | 02:36 PM
BigEd_72455's Avatar
I changed the pump out, cleaned a small amount of trash off the pickup screen from it sitting out, and it is barely pumping any oil out the pressure/cooler port.
i double checked the o-ring and it is fine. No tears or rips.
i am officially at a loss of what to do...
i am going to try to pull the rear panel and check that when they vatted the block, it did nit eat anything out of the back that should be there..
Old Mar 19, 2017 | 03:16 PM
I figured out what the problem is. The rear dumbbell oil plug and the front block off plug are missing from when i had the engine vatted. I have to get those ordered and installed and ill be all set to go.
Old Mar 19, 2017 | 05:32 PM
Wolftrk99's Avatar
I forgot about the plug on the front oil galley, had to go back and look at ny thread ti find the pic....
Old Mar 19, 2017 | 10:01 PM
Brianwilson1990's Avatar
Registered User
Any pics of these parts? I has pressure issues too and this is my first ls engine build
Old Mar 20, 2017 | 12:15 AM
Wolftrk99's Avatar
The front plug is in the pic of the front of my engine where the timing cover gasket flares out on the block by the oil pump, the dumbell plug goes basically in same place but in the back of the engine...
Old Mar 20, 2017 | 12:18 AM
Wolftrk99's Avatar
Theres the dunbell in the back of the enginepic came from googling it.... not mine
Old Mar 20, 2017 | 07:48 AM
Look for Enginetech kit # HK119
They call it a "Headache kit" because its got the stuff in there that will give you a MASSIVE headache trying to locate and get ordered.
The later model engines can only use later model dogbone design, and early model can use latw model design, but dont use an early design on a laye model engine.
http://www.saccitycorvette.com/Billet-BarBell.html
that site has a machines piece that has a tighter late model design and tolerance. Go check out their site for information.
Old Mar 20, 2017 | 11:02 AM
Wolftrk99's Avatar
How much is the enginetech kit? I had to get all that stuff from the dealer and spent somewhere around $25-30 for all of it... and the cam retainer bolts came with thread sealant/lock on them...
Old Mar 20, 2017 | 12:05 PM
https://www.ebay.com/itm/142277930676
$24.99 to your door
