Ltft bank 1 very lean/backfire pops and no codes
Old Dec 14, 2013 | 02:09 PM
gbbmk's Avatar
Default Ltft bank 1 very lean/backfire pops and no codes
So a few days ago i noticed a rapping in my motor (the 2004 listed in sig) , I took the truck to the shop that rebuilt the motor and they felt it was a stuck lifter due to oil and the build being so new. Fast forward to today. I started to pull away and the truck was hesitating a bit and bucking not bad but enough to notice. Thought it was cold (its snowing here) Put more of a load on it and it started to pop pop pop in the muffler. Like an unburnt fuel. Then it started to rap intermittently. I went to the local parts store and got some Preston Riesling in hopes to free up a possible stuck lifter. The lifters are the original before you ask, i know they should have been replaced but this is what I am dealing with. I also checked for bad plugs and connections, all the injectors are firing from what I can feel. I took it down the road and the noise was gone but under normal load it still shook, when I punched it it would open up but a definite loss of power. Then I noticed my ltft bank one is very lean. Normally I run =/- 2 cruising on both sides. Now at idle in gear i am +18 on bank one and +1 on bank two. My o2's are bouncing fine and I am not reading any codes. Oh I am using the droid app Torq scan. It doesn't appear to be a vacuum leak and my oil pressure is good. I have not pulled the plugs or checked for compression. Id feels like I am down a cylinder but I am not seeing signs of it other then my fuel trims
I am at a loss and I don't want to destroy what I have put into my motor.
I have searched all morning to find something. I can not send you any logs I can only read data.
Thank you in advanced for your help
Old Dec 14, 2013 | 03:27 PM
Chevy_King1500's Avatar
bad injector? pull the plugs.
use a temp gun on the manifolds to see what cylinder is colder than the others
Old Dec 14, 2013 | 04:20 PM
gbbmk's Avatar
Don't have a gun but I pulled all the plugs on bank one and did a compression test. All cylinders were at 148-155. The last cylinder on the drivers side up against the fire wall plug was bent down. Swapped it. Fired it up. Let it idle for a min. A few taps to the pedal and the intermittent rap came back. I shut it down and here I sit. Waiting. This motor oy has 4000 miles on it. Three oil changes with oil not synth. Third set of plugs jist for break in and new tunes. I'm at a loss.
Old Dec 14, 2013 | 04:27 PM
gbbmk's Avatar
Its running now and the knocking is gone for the most part.but its still running like crap. When I rev it runs more lean on bank one. The only thing I have done is fill up yesterday. Could bad gas do this? Could I have a bad injector, how can I tell, what else should i look for or do?
Update:: The trims are now +/- 2 on my long terms and its not popping. Idle and timing at idle are normal. It still is rough not real bad but a vibration under 2000k rpms. The snow makes it hard to go wot but it feels like the power is there i am just worried about the rough driving down low and the idle. It just feels off. Its not a placebo effect either. It almost feels like a bad u joint vibration but from the block.
Old Dec 15, 2013 | 08:30 AM
gbbmk's Avatar
Well I think, not sure but I think since my combustion chamber is smaller I hit the pkug with the piston. I am running tr5's but the builder said autolite 104 or 103 for nitrous. I guess the ngks are that much longer. That could have been the rapping I heard and why after the new set of plugs I am still getting a vibration similar to a burnt wire. It fires but not well.
Whoever is reading ill update.
Old Dec 17, 2013 | 04:09 PM
gbbmk's Avatar
Bump I'm still stumped and I swapped a coil. Still runjing rough. Burning fuel and blittle blue smoke. Great oil preassure and oil levels are good.
Old Dec 24, 2013 | 05:00 AM
07vmax1500's Avatar
Where's your short fuel trims they are more important to find an issue then the longs as the longs are just an avg. I had a 2500 van had a similar problem no codes but ended up being the o2 sensor.
Old Dec 24, 2013 | 02:34 PM
Suburbazine's Avatar
Keep in mind that "Lean" can be either "Not enough fuel" or "Unburnt Fuel".
If you found a plug bent down then it means someone most likely crossthreaded the plug in the head. You might want to check them all as a crossthreading will cause all sorts of issues and it pretty much requires a competent machine shop to fix. (competent shops don't reuse old lifters, too many risks involved for too small a price)
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
