LT4 cam help
97 5.7 CHEV stock L31
i need some help with selecting springs and rocker arms to go with the cam i appreciate the help that i have gotten thus far but i dont under stand bee hive and other springs the spring that have been suggested to me, have different specs I need some quality springs that doesn't require modification to the spring or the heads but not high dollar cost i need some 1.6:1 rocker arm also can someone also explain how a valve spring works thanks |
Check out this website for spring info:
http://www.racingsprings.com/ Click on the link for "Beehive Springs" for more info on beehives. |
If you are going with the LT4 Hot Cam, just get the spring, rocker, and retainer kit that comes with the camshaft.
