LT install question
Old Jun 14, 2005 | 03:55 PM
Gmc²'s Avatar
Default LT install question
will i have to take my blower off to get the right LT on? or can i go at it from the bottom somehow? pic is of the blower on the truck.
ohh and it will be a set of pacestters.
Old Jun 14, 2005 | 04:08 PM
white1's Avatar
Couldn't you just go from the bottom?
Old Jun 14, 2005 | 06:01 PM
KySilverado's Avatar
My Dynatechs went on from the bottom. Remove the wheel wells to get to the bolts and such.
Old Jun 14, 2005 | 06:21 PM
yackowski's Avatar
Yeah, you can go from the bottom with no problems. The tranny lines are kinda a pain, I had to have a friend "gently" pry them towards the engine before mine would fit betweent he frame. On the drivers side I had to just go ahead and remove the valve cover and it slid right in.
Old Jun 14, 2005 | 10:30 PM
white1's Avatar
I guess I'm just a jack ***, but what kind of S/C is that?
Old Jun 14, 2005 | 10:40 PM
Leroy_454's Avatar
Its the older non-intercooled Magnacharger system. (pre-radix)
Old Jun 14, 2005 | 11:20 PM
quicksilverado's Avatar
When I had The side-mount on I removed the blower and went from the top. Only took about 20 minutes to remove it.
Old Jun 14, 2005 | 11:52 PM
1Blown04's Avatar
I second that
Old Jun 15, 2005 | 12:22 AM
CashDudeHomie's Avatar
If you have ASM's, you'll most likely have to pull it since they don't seem to fit from the bottom. Hopefully you have the Dynatech's.
Old Jun 16, 2005 | 03:58 PM
Gmc²'s Avatar
thanks guys,
