LS6 PCV system
Old Jan 12, 2006 | 05:56 AM
tdrumm's Avatar
Part numbers of what is involved would be helpful too. Thanks
Old Jan 13, 2006 | 12:11 AM
speed01rcr's Avatar
GM P/N 12568002, You simply remove the intake manifold and unbolt the existing cover, then install the new one. Go to this website for further detail. The inline pcv valve I made was a valve, inserted into a rubber hose, then a hollowed out valve at the other end to plug a hose into. Website: www.ls1howto.com
Old Jan 13, 2006 | 12:14 AM
99Silver6.0's Avatar
I did it on mine. But remember, I think its pre 03 blocks will require cutting in the valley for the LS6 cover to work.
Old Jan 13, 2006 | 05:44 AM
tdrumm's Avatar
Good info and thanks for the link!
Old Jan 14, 2006 | 08:20 AM
BLACKHD01's Avatar
Me and a couple of friends did this to my 2500HD this past weekend. It only took about 2 1/2 hours to do and it was pretty simple for the most part. My truck is using between 2-3 quarts in a 3000 mile period. I used the kit from Thunder Racing. The kit was complete, but you will need about 2 foot of 1/4 inch hose to connect the pcv system.
Old Jan 14, 2006 | 10:02 AM
mattrem's Avatar
I just ordered the parts to do mine when we swap the intake next week.
Old Jan 15, 2006 | 09:52 AM
Dark Halo's Avatar
did you have to cut the block?
Old Jan 15, 2006 | 08:05 PM
BLACKHD01's Avatar
No did not have to cut the block. I have a 2001. I think it was the 1997-2000 that you have to cut to get it to fit.
Old Jan 15, 2006 | 08:20 PM
Could have sworn there was a guy on here who had an 02 he wanted to ptu the LS6 cover on. And he had to cut...
If your valley looks like this, you gotta cut!!
Old Jan 15, 2006 | 08:36 PM
budhayes3's Avatar
PT's Slowest Truck
Soooo....this might be a good idea for me when I decide to put the LQ9 together huh? I assume that I could still utilize my AMW catch can for some extra insurance (as a matter of fact, I think AMW makes a bracket that secures their can to one of the cylinder heads for the LSx engines with this PCV system). Or, since I already have the AMW, is it even worth it for me to spend the extra bucks for the LS6 system?
