LS6 intake on 2001 5.3L 1500 2wd?
Old Jan 9, 2009 | 01:48 PM
Mike96z's Avatar
Default LS6 intake on 2001 5.3L 1500 2wd?
I know the LS6 intake will bolt up to the engine no problem but is there anything in the way? Accessories, belts, pulleys? Ill have the Intake, Fuel Rails, Throttle body, map sensor and whatever else I may need. Just wanted to know if its possible and what all I should have to do the install.
Has anyone here did this?
Thanks
Mike
Old Jan 9, 2009 | 01:52 PM
wayfastwhitie86's Avatar
Look on ls1truck.com they have step to step instructions for this mod on the front page. Not tryin to take away from this site but good info.
Chris
Old Jan 9, 2009 | 03:07 PM
Mike96z's Avatar
Thanks Ill look into it.
Old Jan 10, 2009 | 11:19 AM
RADO_4U2NV's Avatar
You will need e-fans and a waterpump from a T/A or Camaro. The truck waterpump wont work because of the spout coming out of the top of the pump. You will also need to cut you idler pulley off of the acc bracket. Thats just a few. Look up bluecajun5.3 he did a write up on it. And if you have questions he will answer them for you.
byrne_06
Apr 29, 2017 02:19 PM
SLOPONY
20
Oct 18, 2016 06:05 AM
LARRY01Z28
Aug 1, 2015 10:15 PM
Cowboy Tom
Jul 21, 2015 10:29 PM
