LS6 AC issue in truck
Old Feb 29, 2012 | 12:42 PM
rkwhite61's Avatar
Default LS6 AC issue in truck
Since I had a v6 in the truck previously, I was planning on using all the accessories from my LS6 with my truck conversion. However, I've discovered that on the '02 truck (harness I'm using) the compressor has a high pressure switch built in the compressor (the rear connector). The ac compressor on the LS6 doesn't have a high pressure switch. Any ideas what to do here? Can I ignore the high pressure connector on the '02 harness?
I thought about just installing a truck ac comp and bracket, but wouldn't you know it.... the pulleys do not line up and best I can tell, this method would require swapping everything to a truck accessory setup.
byrne_06
Apr 29, 2017 02:19 PM
wrb002
Aug 31, 2015 12:00 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
black6spdz
Jul 16, 2015 01:32 AM
Aboss
Jul 9, 2015 10:28 AM
