LS3 head gasket question
Old Mar 22, 2022 | 06:54 PM
shakenfake's Avatar
Shlumpt
5 Year Member
Default LS3 head gasket question
Boring an LS3 out to 4.07 am I able to use a stock LS3 head gasket? Using L92 heads, no milling. Pistons I am looking at are JE 311981. I do not believe I will have PTV issues with this setup.
Just wondering if I can use the stock LS3 gaskets in terms of bore size?
I believe that the LS3 gaskets have a bore of 4.085? Can anyone confirm that as well?
Old Mar 22, 2022 | 11:11 PM
RDF1's Avatar
DuNnO
5 Year Member
im 99% sure your correct.
Sorry i dont have any stock gaskets to double check
Old Mar 22, 2022 | 11:12 PM
shakenfake's Avatar
Shlumpt
5 Year Member
Ees okay buddy
Nobody on LS1Tech answered my question
Guess I need to call someone up haha
Old Mar 22, 2022 | 11:18 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Yes, you can use those gaskets.
The idea is that you don't want the gasket to over hang the bore.
Old Mar 22, 2022 | 11:19 PM
shakenfake's Avatar
Shlumpt
5 Year Member
I just didn’t know how acceptable it was for the gaskets to be bigger than the bore.
Old Mar 22, 2022 | 11:25 PM
1FastBrick's Avatar
Well you do want them larger than the bore. The closer they get to the edge, The more they are going to be subjected to the flame front.
I don't know what the margin of safety is.
But For example, GM states the original 6.0L gaskets are safe for a .020 over bore. The gasket is still larger than that. But I have never measured the bore on any of the aftermarket replacements to see if they are any larger than the OE.
Old Mar 23, 2022 | 12:13 AM
shakenfake's Avatar
Shlumpt
5 Year Member
Gotcha LS9 head gaskets are probably the way to go then since they are 4.100
Old Mar 23, 2022 | 09:47 AM
RDF1's Avatar
DuNnO
5 Year Member
Yea cause everybody uses LS9 head gaskets on 4.8/5.3s.
Old Mar 23, 2022 | 10:25 AM
shakenfake's Avatar
Shlumpt
5 Year Member
@RDF1 Oh yeah that just seems so wrong to me. I'm not an engineer but a 4.1" bore gasket on a 3.78" cylinder seems way big. Not an engineer though so couldn't tell you if that was the right or wrong way to do it.
Old Mar 23, 2022 | 12:18 PM
arthursc2's Avatar
it is some lost space and thus lowered compression for sure. But for the price, LS9 gaskets can't really be beat
