Ls3 can and heads on 4.8
Old 05-20-2012, 09:19 PM
2007chevy5.3l's Avatar
Originally Posted by A Low Dime
LOL you. And Jeff keeps saying you are going to sell the 243s and run L92s.
Yeah a L92 6.2 engine swap!
Old 05-20-2012, 09:22 PM
13 Second Truck Club
A Low Dime's Avatar
LOL Just blame Jeff.
Old 05-20-2012, 09:29 PM
skeet's Avatar
ls7 heads are square port
ls3/l92 retangular port
Old 05-20-2012, 11:11 PM
2011 4.8 killer's Avatar
So would it be best to just get ls7 heads and put on it so I can use my stock intake manifold
Old 05-20-2012, 11:33 PM
chevrolade's Avatar
Lol u can't use ls3/l92 heads on a 4.8/5.3
Old 05-20-2012, 11:51 PM
Hell it doesn't even look like I can use the ls7's either I did just find a custom head and cam kit on vengeance racing though but I'm not sure if it will work or not. I'm pretty well screwed on any of the cathedral port stuff cuz its all for bigger bore stuff. Do is there anyone making a bolt on head for my little *** 3.78 bore 4.8
Old 05-20-2012, 11:54 PM
Resident Retard
BlackGMC's Avatar
I put a set of these on my old 4.8, it ran pretty damn good
PRC Stage 2.5 5.3L CNC Ported Heads
or you could go with these.
PRC Stage 2.5 LS6 CNC Ported Heads
Old 05-21-2012, 09:22 AM
iamkeniff's Avatar
L92/LS3/LS7 can only be ran on a 6.0 block and bigger.
Stick to a 706/243 style head for the 4.8/5.3 block even if it is a bored 3.90" (5.7L) *i could be wrong on the max bore of the 4.8/5.3 block* an if you run a 383 stroker kit it still wont matter because the bore is only 3.90"
Blackgmc posted great head choices for your 4.8
What are the plans for the truck?
Old 05-21-2012, 09:47 AM
Man Motor club
rjwz28's Avatar
LS7 requires a 4.125" bore last I checked, the valves hit the cylinder walls on a 4" much like the LS3/L92 valves hit the cylinder walls on the smallbore LSs. There are LS3 heads designed for the smaller bores (Mast) but they are expensive like crazy, and you might as well swap in a 4" bored engine and buy factory L92s if you're going to spend that kind of money.
Old 05-21-2012, 10:18 AM
My plans are to get a solid top end and go with probably a supercharger or an sts turbo kit just something I can romp in the street and go to the track every once in a while. I would like to at least run mid to low 13s
Quick Reply: Ls3 can and heads on 4.8
