Ls3 90mm tb on nnbs 5.3
Old Aug 18, 2016 | 07:03 AM
Brian Mock's Avatar
Default Ls3 90mm tb on nnbs 5.3
I have a extra ls3 throttle body from a friends vette he wrecked an parted out, I heard stock tb on nnbs is 87mm, so I be able to get a tb gasket for a 90mm an put it on an work? I also work at a shop where I have access so a snap on scanner that is able to do the tb relearn if needed but, besides that it should work right? Or is there another underlined issue someone has ran into when doing the swap
Old Aug 19, 2016 | 08:59 PM
DrX's Avatar
DrX
Should be a direct swap. Seal is on the intake, so none needed.
Old Oct 1, 2016 | 02:02 PM
JL3100's Avatar
Actually you should let me buy it... you'll never get it to work
Old Oct 1, 2016 | 06:15 PM
turboal1's Avatar
Default 90mm T/B
A waste of time for a stock 5.3, I tried it a few years back.
plus you need to change the size in the PCM so it makes
the right A/F ratio. a relearn not needed. just pull off the neg batt cable
for a while.
GM1697
Apr 8, 2016 05:43 PM
Phatchevy
Jun 16, 2002 01:32 AM
Phatchevy
Mar 3, 2002 11:12 PM
Phatchevy
Feb 25, 2002 05:12 PM
FASTZ71
Jan 30, 2002 10:22 AM
