LS2 conversion?
Old Mar 9, 2008 | 12:10 PM
Dark Halo's Avatar
Default LS2 conversion?
Just wondering if all the gen 3 performance parts work with the gen 4 ls2 block? Mainly cam and internals? My local machine shop is selling ls2 block for 950 brand new but I am just wondering if you can use a gen 3 forged roating assembly with the block and a gen 3 cam?
Old Mar 9, 2008 | 07:03 PM
ME Performance's Avatar
from researching, if your using a internals from a Gen3 motor then it should be all plug and play.. u'd only have to relocate the knock sensor fromt he front to the back...
crank has to be a 24X reluctor to work with Gen3 electronics as the Gen4s are 58X reluctor wheel... not too sure why...
Old Mar 9, 2008 | 10:40 PM
1Topgun's Avatar
From what I understand, the LS2 (Gen 4) knock sensors are on the sides of the block, and have to be converted to the Gen 3 type. Also, the Gen 4 cam sensor is located on the timing cover, instead at the back/top of the block. There's an aftermarket wiring harness/extension available that connects the cam sensor and knock sensors to Gen 3 wiring.
I believe the 58x reluctor allows more precise ignition and fuel injection timing than the 24x.
Old Mar 10, 2008 | 06:38 AM
Dark Halo's Avatar
Who makes the harness and what type of valley cover does the ls2 use. Is it like the ls6 or would you still use a pcv valve?
Old Mar 10, 2008 | 12:13 PM
1Topgun's Avatar
Casper's Electronics make the wiring harness...here's a link: http://www.casperselectronics.com/mm...Category_Code=
From what I understand, an LS2 has the PCV tube on the valley cover similar to an LS6. Pic:
Old Mar 12, 2008 | 06:52 PM
Dark Halo's Avatar
thanks that helps alot
gmcyukon
Oct 5, 2015 06:20 AM
Silver8ado
Sep 30, 2015 11:42 AM
trxmxzx
Sep 29, 2015 07:42 AM
maxspeed05V
Sep 23, 2015 10:48 AM
spooneralmighty
Sep 11, 2015 02:28 PM
