LS2 Conversion
Old Aug 25, 2005 | 08:08 AM
Default LS2 Conversion
I have not heard of anyone doing this in a truck yet. Anyone have any info on it? I think it would be a good discussion.
Old Aug 25, 2005 | 09:13 AM
I thought about, but everyone just said it would be easier to do a 6.0 swap than the LS2. So now I building a 6.0 for my truck. Should be in about 2 weeks or so.
Old Aug 25, 2005 | 10:44 AM
I did some reading and I think the iron 6.0 is very similar to the LS2. The difference is the placement of some sensors and the way the accessories mount up. I don't think it would be to difficult.
Old Aug 25, 2005 | 10:47 AM
BigTex's Avatar
If I ever have to swap motors for some reason, I will be going with a LS2 based stroker. The block is updated for displacement on demand, which required the cam position sensor to be located up under the front cover. It also moved the knock sensors from the valley cover to the sides of the block. Otherwise, it should be the same physical dimensions and all your current accessories should move over.
Old Aug 25, 2005 | 10:56 AM
Of course you would know. Thanks Tex.
Old Aug 25, 2005 | 11:06 AM
NXRICKY's Avatar
Former Vendor
Check out flippers truck, he did it. If I remember right it was a pain in the ***.
Ricky
Old Aug 25, 2005 | 11:10 AM
BlownChevy's Avatar
blownerator
25 Year Member
LS2 is an easy conversion when it comes to hardware.....There will be some work involved with sensors and software.
Old Aug 25, 2005 | 03:57 PM
CHarris's Avatar
Yeah... I think I heard the knock sensor is a pain in the ***. Supposed to be a completely different system I've heard.
gmcyukon
Oct 5, 2015 06:20 AM
Silver8ado
Sep 30, 2015 11:42 AM
trxmxzx
Sep 29, 2015 07:42 AM
maxspeed05V
Sep 23, 2015 10:48 AM
spooneralmighty
Sep 11, 2015 02:28 PM
