ls1 swap need info fast.
Old Oct 17, 2003 | 03:38 PM
2003blue5.7's Avatar
Default ls1 swap need info fast.
I have my motor out and the ls1 sitting net to my 5.3 and the ballencer is different. I am running my truck acceseries so can I use the ballencer off my truck???
Old Oct 17, 2003 | 03:50 PM
CashDudeHomie's Avatar
Default Re: ls1 swap need info fast.
yes
Old Oct 17, 2003 | 04:02 PM
Ryan23silverado's Avatar
they do the same thing, just the truck balancer sticks out approx. 5/8" further foward than the LS1 balancer. if you want to use truck accessories, definaltely use the truck balancer otherwise the belt will not lign up if you use the LS1 balancer
Old Oct 17, 2003 | 04:33 PM
thanks allot guys.
Old Oct 17, 2003 | 07:06 PM
RChevy4.8's Avatar
You should check out www.ls1truck.com, I am sure they would like to see what you have planned for your truck and some picks of the install.
Old Oct 17, 2003 | 07:53 PM
Yelo's Avatar
you will have to mod the truck alternator bracket by welding or bolting a plate in place so you can move the idler pulley over and down approx. 4"...if you do not the throttle body will not clear the idler pulley
Old Oct 17, 2003 | 09:28 PM
thanks guys. I'm close to being done.. just bolting up some little stuff.
Old Oct 18, 2003 | 03:25 PM
by the way that was bad info on moving the idler pully I didnt have to do that.
Old Oct 18, 2003 | 04:10 PM
That's only if you use the LS6 intake. I assume you reused the truck intake.
Old Oct 18, 2003 | 06:56 PM
yep all the truck stuff went back on.
