LS1 swap?
Old Oct 10, 2003 | 08:40 PM
red53gmc's Avatar
Default Re: LS1 swap?
All of the gen III engines are interchangeable. The only differences are the accessories. As long as you use the truck accessories it will bolt up fine...except for one bolt on the alt bracket--no problem not having that. Your 5.3 pcm will work, but it will run alot better with a tune. The coil bracket *may* be different though, I'm not sure. The 5.3 heads will up the compression to about 10.8:1 or so, but the intake valves are smaller unless you work the heads first.
Old Oct 10, 2003 | 09:03 PM
2003blue5.7's Avatar
what kind of times can I expect I run a 15.6 with my 5.3 what do you think the ls1 would do for me stock?
Old Oct 10, 2003 | 10:43 PM
gonzo 6.2's Avatar
The one bolt that wont go in is an A/C bracket bolt as i understand and it wont hurt a thing to go without it.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
RONIN LSX
Aug 11, 2015 12:03 AM
Denali08
Aug 9, 2015 04:34 PM
vmaxpro
Aug 4, 2015 07:02 AM
Black-Syde
Jul 6, 2015 02:12 PM
