2nd gen rx7. i know for a fact that an ls1 will work, they make kits, and as long as the ls1 and the truck blocks are the same it will work.
Cool beans. That sounds like it will be really cool! Post up some pics of the progress! What trans and rear-end are you planning on using? :) |
I know it you cant bolt the LS1 pan up to the 03+ trucks because of cross member but you should be cool with a RX-7!
He's not asking if it will fit in our trucks, just if it will fit the block itself, and like they said above yes it will, all gen 3 blocks will fit it, F or Y body, or truck pans are interchangeable. |
I understand he is talking about a RX7 can you read? I couldnt use the F-bod pan with my setup because of the c-member. |
Yes i can read, no where in his question did he ask what oil pans would fit in our trucks, which is what your reply was, he asked if the actual pan would fit the motor, so thanks for the help there bud. |
i havent made any progress yet besides remving the 13b and 5 spd. i wanted to make sure it would work before i spent my mula. im probably going to have to do something with the intake as well as the oil pan, as it will be 3 inches taller than the LS1 intake and the LS1 already barely fits. this shouldnt be a problem though because everyone around this board has LS1 intakes just sitting in their garages from when they switched to LS6's...and someone should give me their useless old LS1 intake for shipping costs. :D |
he probably just added that bit about the truck because i posted in the truck forum.
Exactly and I understand that the pan will fit to the block but you usually put a block on a chassis or at least thats what do!
Yes i know that motors usually go on chassis' his is going on a RX7 not a truck like stated in the beginning, which i read, just didn't like being asked if i could read, since my original response was a direct answer to his question, because i read it, not stating facts non-pertinent to the question, as to keep the post from getting off subject as this has, so i apologize to the originator, and hope that all your questions have been, are being, and will be answered, as this site is a very informative one. |
