LS1 Into 03 Silverado?
Originally Posted by VortechC5
As soon as LS1Edit is available for the 03 trucks I'll upgrade mine and hit the dyno.
You might check with www.hptuners.com
Originally Posted by SportSide 5.3
2003blue5.7
how much did the entire swap cost you?
$zero for the motor.... He He
just oil and colant really.
Gaskets got from Dad Well "powertrain plant" shhhhhhhhhh
Originally Posted by black5.3
Will an LS6 work the same way on a 2000 silvy? Found a complete LS6 for only $6500!!
For that kind of money, you could drop a 370 shortblock in and a set of stage 2 heads. Or a 409 shortblock. There is not enough difference between the LS^/LS! to justify the difference in price IMO. Basically it's xcam swap and oil porting holes in the block. Yes the heads are different, but again, you could get into a worked LS1 block and heads for under that price.
