Ls1 fan and nelson harness ???s
Old Mar 12, 2006 | 04:02 PM
virgils4.85spd's Avatar
Default Ls1 fan and nelson harness ???s
I installed my fans 2 weeks ago or so. They work fine and the pcm turns them off and on correctly but i cant get them to come on with the ac!? I spliced into that green wire that matched the green colored wire on the nelson harness and .... nothing! I know its not a must but the air sure is colder when theyre on. Is it the relay? Its the 2 relay harness. If someone knows what might be wrong let me know.
Thanks,
Derek
Old Mar 12, 2006 | 04:08 PM
white1's Avatar
Possible your splice isnt good, or youre on the wrong wire.
Old Mar 12, 2006 | 04:15 PM
Default I even..
took the wires and hooked them together bare copper to bare copper and nothing. Its the solid dark green wire right!?
Derek
Old Mar 12, 2006 | 06:51 PM
98TAauto's Avatar
its 2 green wires in their.. i think i tapped the wrong one when i did mine..
the fans cut off and on when the temps hit 200ish? Or do they not come on at all? Its possible you didnt push the pin all the way into the pcm. Its a PITA!!! I had to pull the plastic clear peice off and get mine in right.
if thats in right, splice the blue wire that goes to the pcm. Hook a wire to that splice and ground it to the battery. The low speed fans should kick in if its grounded right. Thats just to letcha know they are working if they arent cutting on at all
Old Mar 12, 2006 | 09:34 PM
SnakeOiler's Avatar
Thanks,
Derek
"they" work fine - so, you are saying that you see both fans coming on and off? Please explain.
With a two relay setup, each fan is on a dedicated circuit. Fan1 controlled by the pcm and fan2 controlled by the a/c compressor circuit. Fan2 will 'turn on/turn off' in conjunction with the compressor. The best test is to turn on the HVAC blower fan and set the HVAC to the defrost setting. This will cause the compressor to cycle on and off, thus the Fan2 will cycle on and off. If it does not, then something is not connected properly.
If Fan2 actually comes on when the a/c is off and the HVAC setting is on vent, something is not connected properly.
Old Apr 9, 2006 | 11:03 PM
Red Heartbeat's Avatar
I know this is an old post but you're most likely hooked into the wrong wire. I believe the wire has a stripe on it. I've seen this many times before.
maxspeed05V
Sep 23, 2015 10:48 AM
kalikid06
Sep 20, 2015 07:46 PM
Dawas
Sep 20, 2015 12:00 PM
97gmc
22
Sep 8, 2015 10:56 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
