LS1 fan install....somebody wanna help me out?
LS1TECH Sponsor
i put lt1 fans in my old sierra, was a snap and easy. my site isnt as detailed as the other but it will run cooler and free up a lil power
http://www.geocities.com/victoryredzr2/lt1fans.html
LS1TECH Sponsor
if my memory is correct yes, there was one the thermo assy. i bought, and i wired the override switch to the a/c side of the thermo assy. instaed of ac system. basically they cam on at 160ish or when i flipped the switch.
Originally Posted by 02denali
dc controller is made by dc controller. it is a wonderful unit. mac has the sight there. all you will need is the 35amp unit. this unit has worked well for me with no problems at all. with this unit my fans have never went over 50%. this keeps my truck plenty cool and draws half the amps. if you have any more questions lemme know.
This sounds pretty good.....not too bad to be out a couple hours labor and have e-fans for about 170 bucks
Also, i dunno if this should be something i probably need to ask them. But im going to be running a ASP pulley and i noticed that they have a U/D pulley loop on the controller that makes the fans always run at 10% but it makes them run at 100% with the a/c on.......i was wondering if that would be too much draw for wiring the fans in parrallel or if just having it with the normal 50% on during a/c would be enough.
its near the limit but worked ok i think the fans are 10-15 amps each tops,
Aaron
Formerly one92rs
yes the fk35 is it. i had an underdrive pulley and i left it alone.it never got hot and i have a 160 therm. if it does get warm then the fans will come on faster. it comes with the wiring -instructions-and everything needed.i simply wired my fans together behind the shroud and ran one ground and one hot to the controller. it works great. be sure not to overtighten the nuts on the terminals. they only need a little tightening.
