LS Truck Intake Shave Plastic Welding is Easy "How To"
Old Jun 11, 2014 | 11:08 AM
  #21
AGearHead4Life's Avatar
Originally Posted by turbo4.8
How the heck would one of these be ported?
Originally Posted by Chevy_King1500
they cut them in half and then glue them back together
^^ yea, what he said.
Old Jun 11, 2014 | 12:12 PM
  #22
TXsilverado's Avatar
Originally Posted by AGearHead4Life
All I can say this stuff is strong. Read my last post comparing how it was assembled/fused from the factory. What I have done is stronger. I punched each of these pieces after welding and see zero flex. It is solid.
I think the intake see most vacuum at idle. So every time it idled would be a test.
I'm thinking about mounting it onto my extra motor and riging up my air tank to it to test 20lbs of boost. lol
punching it wont show any flex or buckle. revving it from neutral to high rpm will make it flix and buckle by going high vacuum to low vacuum. i've witnessed a fast 102mm flex and buckle like crazy and it's a $800 intake.
Old Jun 16, 2014 | 12:58 AM
  #23
Intersting. Yea, I wouldn't have expect a FAST to flex. They appears solid also.
Old Jun 16, 2014 | 01:30 AM
  #24
oakley6575's Avatar
Check some videos out on YouTube. Pretty crazy to see how much they actually flex.
Old Jun 16, 2014 | 01:43 AM
  #25
I'll do that.
  #26
Still photos have been added to the first post.
Old Jun 16, 2014 | 06:54 AM
  #27
Atomic's Avatar
I have a gauge for that
My factory truck intake without any mods flexed probably 1/2-1" in the middle when going from high vac to low vac.
Old Jun 16, 2014 | 11:48 AM
  #28
Wow, thats crazy. That explains the posts that are in the intake then. I was thinking about removing them, maybe I won't. I've heard people saying thats what they remove in the LS2 intake when they port it. The posts inside the intake that go from bottom to top.
I searched "LS1 fast intake flex" and a few other ways of wording that on youtube last night and didn't find anything. I must be wording it wrong.
Old Jun 16, 2014 | 02:13 PM
  #29
Atomic's Avatar
Doing some easy math lets say the surface area of the outside of the intake is 18"x6" (just guessing sitting at work), thats 108in^2. Idle vacuum is usually 7psi (50kpa) or so with a daily driver type cam, so thats 108*7=756lb trying to crush the intake.
On hard decel, manifold vacuum drops down to 20-30kpa, so 3.5psi, 180*(14.7-3.5)=1210lb.
Old Jun 16, 2014 | 02:36 PM
  #30
Holy crap! Never saw it that way. wow!
BTW you just gave away your job description Mr Engineer....
