LQ9 misfire at idle only
Old May 16, 2014 | 04:34 PM
XLV750LAURENT's Avatar
Registered User
Default LQ9 misfire at idle only
Owner of a 2004 Escalade ESV, LQ9 Engine VIN N 6.0L Vortec, with 50 000 Miles on it, I have misfires at idle only.
Going through troubleshooting, cyl #2 is the offender cylinder. All tests have been done on this engine, except leak down test. I checked coils, injectors, spark plugs, plugs, intake gasket replaced, vaccum smoke test performed, PCM recalibration with J2534 device, MAF sensor cleaned, compression test done, see results in PSI:
CYLINDER PUFF 1 PUFF 2 PUFF 3 PUFF 4 PUFF 5 PUFF 6
2 116 148 165 177 183 190
4 120 153 173 185 195 200
6 115 152 173 186 193 202
8 83 123 155 172 182 190
1 81 128 156 174 183 191
3 81 133 158 176 188 198
5 105 148 172 189 199 206
7 110 150 174 187 196 200
So no issue to report on compression test, vaccum is around 19 inch Hg, so good also.
I made many measurements with the picoscope to analyze the pressure waveform into the cylinders, and seems like intake valve on cyl#2 is leaking.
As I need to remove the heads and replace valves, I would appreciate any recommandations on which parts I could install to get better performance on the LQ9 engine; any suggestion on rocker arms, valves, springs? Camshaft?
Street application only.
Thanks!
Old Jun 5, 2014 | 09:13 AM
SUTTERERMAN85's Avatar
I would swap coil packs from side to side and swap wires as well and see if it goes to the other side. Also check valve springs.
bearden86
26
Nov 15, 2015 03:58 PM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
The_W
Oct 1, 2015 02:35 PM
