Lq9 Low oil pressure when engine is cold
Old Nov 18, 2014 | 08:40 PM
  #21
skaffy03's Avatar
Not trying to hijack,
I have the same issue on my 04 Tahoe. 5w-30.
About same pressure as you when it's cold and doesn't like to move until warmed up. But once its warm, I can run that motor very hard and I'll see oil pressure at WOT go high, almost pegged, like it normally did when I first bought it. But in the summer months, or any time above 25 degrees, its at normal pressure.
Keep us updated if you find anything! It's dropped from 50* here to 10* in one night... and this pressure issue scares me with those temps.
Old Dec 5, 2014 | 05:21 PM
  #22
1SloLQ9's Avatar
I talked to engine builder tonight he said he knows it's sludge on pickup screen and to run engine flush for 30 minutes at idle. Dump and do it again.
  #23
1SloLQ9's Avatar
I was also thinking oil filter bypass valve
Old Dec 7, 2014 | 09:42 PM
  #24
1SloLQ9's Avatar
Well I drained the oil. Put 4 quarts of diesel in the engine and let it sit over night. ( did not run engine with diesel) drained it and it was still pretty clean.
Next I put 4 quarts of 10w40 and 2 quarts of gunk motor medic and let it idle 30 minutes with new filter and dumped. Looked like new oil coming out.
Borrowed a scope from a buddy and looked inside engine from drain plug hole and it's extremely clean. Pickup screen had no gunk whatsoever. I put a new oil filter bypass in block I will put straight 5w30 in it with no cleaners and a new filter and see if its. Fixed. It had 30psi cold with the 10w40 and 2 quarts of motor medic.
Old Dec 11, 2014 | 03:26 PM
  #25
01silvy's Avatar
My guess would be it is oil pump or pickup tube o ring related. I know your tired of throwing parts at it but according to the mechanical gauge your oil pressure seems to be within spec. Dont forget that any wear in the main/rod/cam bearings will cause the oil pressure to be a little low. I say just run a good quality oil and filter and keep a ear out for any unusual noises until you really figure out whats wrong with it.
Old Dec 11, 2014 | 08:12 PM
  #26
1SloLQ9's Avatar
Yeah I'm pulling it apart and putting in updated o ring and new timing set
Old Dec 25, 2014 | 04:14 PM
  #27
1SloLQ9's Avatar
I pulled pan and checked pickup tube for leaks and cracks it was fine. O ring was black and crusty and flat on the sides. Put ls2 timing chain in it along with new sprocket s all new gaskets and I fired it up and it has 47lbs cold idle now.
So it's good to go !!!
Old Dec 26, 2014 | 09:11 AM
  #28
Mangled03gmc's Avatar
Baltimore Whore
So what your saying is the o-ring on the oil sump tube was the culprit ?
Old Dec 26, 2014 | 01:53 PM
  #29
1SloLQ9's Avatar
Yes it was the o ring, I bought a gm red one, Still was hoping it would fit a little more snug than it did, but oil pressure is almost 50 psi now with amsoil 5w30 and a napa gold filter so i'm happy.
its about 33-34 at hot idle after getting on it. It will go all the way up to 80psi by 4500rpm, Has about 50 cruising hot at 2000rpm
Old Dec 29, 2014 | 07:33 AM
  #30
xdmikey's Avatar
How often do you change the oil? I have 215k and when driving I'm at 58
My oil changes are at 3-3300k. Always have been.
But since reading your thread methinks it may be time for a new timing chain, due to some slop sounds coming from the motor.
Glad you found the cure.
