Lq9 Low oil pressure when engine is cold
Old Oct 22, 2014 | 03:18 PM
1SloLQ9's Avatar
Default Lq9 Low oil pressure when cold UPDATE
I have a 2003 lq9 118k that i swapped into my 2006 silverado 1600, Truck has 212/218 high lift cam and pac springs, When I start my motor after truck has sat a day, oil pressure is about 32lbs, I noticed it was low to my standards, I let it idle for a bit and take it for a cruise, after about 5-10 minutes of driving the oil pressure creeps up to about 45psi at 1500 rpms and if i stop to idle its in the upper 30s, Could this be an o ring issue or just a bad sending unit?
I used the sending unit from my 2006 l33 engine and never had the issue. I also tried new oil filter different brand and no difference.
When motor is started cold i can rev it to say 2000rpm and psi does not move from 32psi. I dont dare rev it any higher incase it is an internal engine issue not just a sensor.
Old Oct 22, 2014 | 03:51 PM
turboal1's Avatar
Default oil press
it does sound low, cold should be around 60 psi i think.
what weight oil are you using ? brand of oil ?
Old Oct 22, 2014 | 04:51 PM
1SloLQ9's Avatar
Using Amsoil 5w30 hdd oil. Napa gold filter. No difference between it and the 5w30 Pennzoil and purolator that were in it.
Old Oct 23, 2014 | 12:53 AM
turboal1's Avatar
Default oil press
try a 10-30 and see what it does, I moved up to the 10-30 Mobil 1
last year when i heard guys having oil probs with 5-30.
I only use AC Delco filters. where are you taking the readings from ?
is it a factory gauge or aftermarket ?
Old Oct 23, 2014 | 06:02 AM
1SloLQ9's Avatar
Default facy
Factory gauge.
Old Oct 23, 2014 | 06:03 AM
1SloLQ9's Avatar
I just spent $65 on the oil in it less then 100 miles ago. I'm not going to dump it and run 10w30 going into winter
Old Oct 23, 2014 | 06:06 AM
1SloLQ9's Avatar
I am going to try another sending unit. My friend who sold me motor never had this issue.
Old Oct 23, 2014 | 04:03 PM
GM_Devil's Avatar
was the oil pickup tube ever removed when you did the motor swap? cuz if so the o ring might not be seated properly giving you low pressure.
Old Oct 23, 2014 | 07:59 PM
1SloLQ9's Avatar
Just swapped engines nothing else. Cam was already in
Old Oct 23, 2014 | 08:39 PM
01silvy's Avatar
Could possibly be some sludge in the pickup tube screen
