lq4 or lq9
9 Second Truck Club
If you are running NA, or light boost the early LQ4 with the light rods will come on harder than the later. Those heavy rod engines swing another ~60g of weight per cyl vs the light rod. Lq9 with the higher compression will make up for it. The HD rod engines do have a much better piston and don't slap near as bad as the early mexico piston engines.
so i get a 2005 yp lq9 if i can find one. but if i find an lq4 for a good price i should get it and change pistions anyway and it will be just as good as lq9. i heard some of the lq4 or it could be lq9 dont fit in because it has a longer crank or somethings should i stay away from motors before 02.
If your buying a converter anyway, you can get a 99-00 LQ4 cheap cause nobody thinks they will work. Just tell your converter guy what you have and he can make a converter to work with longer crank at no additional charge. I have a 2000 LQ4 with a Yank ProTruck 3600. I bought my short block brand new for $300. I installed ARP hardware, made flycuts, and put my 243's on it. That gives me more piston to valve clearance and more compression then an LQ9...
so im looking for an lq9 out of something 2005 or newer and silv ss or escalade. the motors in the ss and escalade make 350 hp. im planning to buy a used scrap yard and rebuild. there will be a stamping on the block somewhare. ehare is the stamping. and do the lq9 have aluminum heads. the lq9 willl bolt into my 02 silverado z71.
Honestly, unless you're planning major numbers or spinning to the moon, either will be fine
LQ9's have aluminum 317 casting heads, as do 01+ LQ4's
I'll blow it up and build another before I ever part it out. The converter will work with any other LSx based block if I use the crank spacer needed for a LS to TH400 combo and my 2500 flat flexplate. So its really not a problem, I'm sure someone would be more them happy to buy this converter only needing a crank spacer to go to 4l60e. Plus its the Pro Truck, which means its lock up clutch is the same as what a 4l80e verter would have. Which still allows me to tow with my truck and Yank converter. When kids talk a load of **** then when its time for the track to open they can't get their car down there. It is funny when I can (and have) offered to tow them to the track "SMOKE THEM" and then tow them back home...
