Lq4 Cam selection
Old Mar 5, 2025 | 04:46 AM
Torgeir's Avatar
Default Lq4 Cam selection
Hi there,
I'm new to this forum
And from Norway..
I am looking for torque in the Operating RPM Range: 800 and up,
Building a new engine.
Block Lq4
bore 4.005 in.
stroke 3.622 in.
Deck Height 9.235
Piston:
pro LS 2618 Forged Piston, 4.005 bore, 1.326 C.H., 2cc Flat top
Compression Ratio 10.7:1.
Connecting Rods:
Eagle SIR I-Beam SIR6100NL
Crank with associated parts are for balancing.
Cylinder heads:
243 Cathedral
Combustion chamber volume: 64cc
- Intake runner volume: 237cc
- Exhaust runner volume: 86cc
- Intake valve diameter: 2.00in
- Exhaust valve diameter: 1.55in
I have listed 2 camshafts, but there are many more to choose from.
which cam is best for this engine setup?
BTR, Stage 1 Truck V2, 206 int./212 exh. Duration, 0.553 in./0.553 in.
Lift, 112 LSA
TSP Stage 2 High Lift Truck Cam: 212/218 .600/.600 112 LSA
Anyone tried this setup?
Trying to get the torque as far down the RPM range as possible, from 800 and up.
2002 Tahoe
gt4 3.73 gearing
4L65 transmission.
Please give me some input.
I'm not very good at English, I hope you understand.
thanks
Torgeir
Old Mar 5, 2025 | 07:03 AM
RB04Av's Avatar
5 Year Member
That "Stage 2" cam is well and widely known to be suitable for such a situation. Although, since the stock torque converter stalls at about 1750 or 1800 RPM, torque at 800 isn't that much of an issue, since the engine will never be at that low RPM when power is being called for. That's the cam I would choose.
Old Mar 5, 2025 | 09:46 AM
Torgeir's Avatar
Thanks for the feedback
Driving with a trailer at 50 mph with
RPM 1450-2000, here in Norway is normal driving
most possible torque in that range.
How much is it possible to get with the right cam in that range?
Old Mar 5, 2025 | 05:51 PM
strutaeng's Avatar
5 Year Member
How much are you towing? Tire size?
Maybe some 4.10 gears will help? That won't actually get you any torque at low RPMs, but rather will increase the RPM so you can get the power to the ground.
To get more TQ at lower RPMs, have you considered a stroker crankshaft? That will increase displacement, and will yield more torque down low. 3.90 or 4.00 stroke.
Old Mar 7, 2025 | 07:14 PM
68Formula's Avatar
Order a custom Cam Motion 204/210 112+0 .553/.570.
onebadtwo
Mar 2, 2022 09:16 PM
gingerbeard
Nov 21, 2021 08:17 AM
07NBSChevy
14
Nov 29, 2016 09:20 AM
BURNRBR
Feb 23, 2012 02:16 PM
hirdlej
Mar 17, 2008 01:12 PM
