LPP vs OBX vs Pace Setter?
Old May 9, 2009 | 01:42 PM
FireMedic331's Avatar
Default LPP vs OBX vs Pace Setter?
What are the difference's between these header? Quality, fit, hp gains ect. I am going to be ordering some Monday and would like to hear your suggestions.
Thanks
Old May 9, 2009 | 03:20 PM
Jeteys5.3's Avatar
good question. I can't decide between Pacesetter's coated or the LPP's. I wanted LPP's but now i see they can have issues rubbing the steering shaft so im still undecided....but the LPP's being stainless is a big advantage.
Old May 9, 2009 | 03:23 PM
Mangled03gmc's Avatar
Baltimore Whore
I ma going to say no difference in power gains, at least none that you will be able to feel... OBX doesn't have a 3 inch collector.. It is between LPP or pacesetter if you don't want to spend money for other stainless headers... If you get alot of rain, go with stainless if you don't the pacesetters will work fine... Just hope LPPs fit when you get them
Old May 9, 2009 | 03:42 PM
I have the OBX on my SSS and they fit perfectly and im AWD. The OBX';s are verry nice.
Old May 9, 2009 | 04:23 PM
sonoma43's Avatar
the coating on the pacesetter's suck!
I have only had them on for 8 months or so but they look like already
Old May 9, 2009 | 04:54 PM
BigMikeGXP's Avatar
Just installed the pacesetter coated headers. They look good now, not sure how they last. I didn't like how the drivers side collector was angled to the ground and not straight like the passenger side. Also had to grind on the dipstick tube bracket and bolt to get it to thread back on. The flange sits very close to that mounting hole. No flanges on them either, had to weld them on.
Old May 9, 2009 | 05:39 PM
GMCtrk's Avatar
The pacesetters are garbage compared to the OBX's. The LPP's should be very similar in quality to the LPP's. Both the LPP and OBX have disadvantages. The big advantage of the OBX is the 3 bolt flanges on the collectors. Slip fit is inferior unless the pipes are perfectly circular which is pretty rare in my experience. The disadvantage on the OBX is the hump on the driver's side, causing burnt plug wires. The LPP's have slip fit collectors. All in all, I'd go with the LPPs. And for Mangled, the 2.5" collector on the OBX's isn't an issue. I went very good with my mods with them (Dynas - identical design) and KySilverado is in the 11s with those tiny 2.5" collectors
Old May 9, 2009 | 06:38 PM
Jeteys5.3's Avatar
i want the LPP's.......but i will be pissed if i order them and once installed they rub the steering shaft and i have to remove them
Old May 9, 2009 | 07:13 PM
As for the hump on the OBX's just get some custom cut MSD wires and some heat sleves and call it solved! Thats what I am doing no probs at all now!
Old May 9, 2009 | 07:21 PM
Baltimore Whore
I say FABO a 2.5 inch collector
