Loss of power
Old Sep 15, 2007 | 10:44 PM
DenaliMax's Avatar
Default Loss of power
Hey everyone, I just joined this site in search of some help. I have an '06 sierra denali which is not under warranty as it was a wrecked rebuild. At certain times, I dont have any power. When I give the engine gas, my RPM's rev but I don't have any acceleration (0-60 time is around 16 seconds), and it is sometimes very hard to get it past 60 mph. Most of the time if I shut the engine off, start it up, shut it off again, and restart, it will run fine after that. (Most of the time it also seems to run fine again if it has been sitting off for more than 15 minutes). It is really hard to explain the symptoms, but the truck will downshift like it is supposed to, it just doesn't take me anywhere. This first happened a couple of months ago just a few times, but now it is occuring on a daily basis. There are also no codes thrown and I had it scanned while it was acting up and nothing showed. I cleaned my MAF sensor and it didnt happen for 2 days but is now reoccuring. Could the MAF sensor be shot? Any help is appreciated as I don't know where to look anymore. Thanks
Old Sep 16, 2007 | 03:50 AM
NBM2001WS6's Avatar
maf could be the culprit, but check the simple/cheaper things first.
when was your last tune-up(fuel filter/fuel sock on fuel pump intake, spark plugs/wires/coils, and air filter) look at those things first then have your maf checked (a friendly guy with HPT for your truck would be cheaper then the dealer)
Old Sep 16, 2007 | 06:24 AM
912jonathon's Avatar
it sounds like a tranny slip
Old Sep 16, 2007 | 06:17 PM
Grumpy5.3's Avatar
I bet your cats are stopped up.... the 06 will not have a fuel filter
Old Sep 16, 2007 | 06:56 PM
DBW(drive by wire)...sometimes it'll exhibit the same probs. you're describing.
Superman09
Sep 25, 2015 05:55 AM
jtphelps289
Sep 11, 2015 06:37 PM
MA$TER_E
Sep 9, 2015 03:14 PM
01 5.3
Sep 2, 2015 02:17 PM
