loss of power
Old May 19, 2005 | 05:34 PM
silverado83's Avatar
Question loss of power
i got an 03' silverado and recently put an 80MM BBK TB on it along with a TB spacer and CAI, the problem is when i put it to the floor i get a reduced engine power at about 4500-5000 rpms and when i check the code it says throttle module input. What could be the reason behind that, some say it could be my throttle position sensor or just the TB itself, if someone could help me out i'd appreciate it. it has a 5.3 also.
Old May 19, 2005 | 10:39 PM
is your truck stock if i were you id take the tb off we put the bbk 80mm on a 04 GTO that was stock did a before and after on the dyno and the car lost hp unless you have a blower or turbo or lots of hp, its not worth it
Old May 19, 2005 | 10:56 PM
v8
17,16,15,14,13,12,11 Drvr
When i first got my BBK T/B i lost a .5 in the 1/4 due to no tunning for it, also with the T/B space your blocking alot of air that you have opened up with the 80mm. One of them is going to have to go. I gained 10rwhp with the BBK after tunning for it.
Old May 22, 2005 | 06:23 PM
Default took off the spacer
i took off the spacer and i am still getting a reduced engine power, i took it to the dealership and they are now saying that it could be one of the many sensors within the throttle, they said the main ones that could cause the problem are the three in the pedal so i dont know, if you know anything let me know please...
Superman09
Sep 25, 2015 05:55 AM
jtphelps289
Sep 11, 2015 06:37 PM
MA$TER_E
Sep 9, 2015 03:14 PM
01 5.3
Sep 2, 2015 02:17 PM
