Looking for real world experience with btr stage 2 truck cam
Dyno numbers or just how it feels. Looking to stay with a stock convertor for money reasons. Truck isn't a dd as I have a Company truck.
2004 sierra 5.3 2wd rcsb, long tubes with off road y, 3.42 gears and 22" wheels (truck is a turd with these heavy wheels). I do tow a little bit throughout the year. |
I just installed the BTR Stage 3 cam, truck picked up 51hp at peak.pulls great especially up top http://www.gm-efi.com/tech/btr-bumpstick-wake-call-blue-magic-finds-groove/
You will probably want to install 3.73 or 4.10 gears. I have a stall convertor already and I am doing gears soon.
The Stage II looks very similar to the Comp Cam 112/118 high lift.
Stg. 3 right here still needs a retune but you can definitely feel the kick above 3k. It has really good street manners Imho but I'm in a heavy cc so tc is gonna be a must
to the guys that have used the BTR stage 3 cam, did you guys use your stock pushrods? i saw that it said you are able to use the stock pushrods
Originally Posted by josueh95
(Post 5272402)
Btr cams are speced by liljohn
Originally Posted by George C....
(Post 5272425)
I reused stock pushrods and I also have a stall convertor(3200). I would recommend a stall with the stage 2 also but you could go lower like 2500. However it's not required.my truck is a RCSB as you can see in the article.
