limited slip vs eaton diff help me on this
Old Jan 12, 2003 | 10:46 PM
blemoine02's Avatar
Default limited slip vs eaton diff help me on this
look i got a limited slip from tahoe with 3.42and i dont know if i should just put it in the rear or should i buy a eaton i no its better but if i allready have the limited slip should i try to buy the eaton before i do this i use it for evryday use travel a littel but like to super charge later single cab 5.3 lots of mods and should i go to a 3.73 or stay 3.42 <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jan 12, 2003 | 11:10 PM
StupidFast's Avatar
Default Re: limited slip vs eaton diff help me on this
I hate my GM limited slip. It only works when it wants and now it dosen't work at all. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> I have always had problems with it. Last monday I laid down 150 ft of my right rear tire. I am not joking 150 ft and it never caught. I would go with 3.73. I am about to return to 3.73 in my truck and let GM pay for another limited slip, just because it is free. Good luck.
Old Jan 13, 2003 | 12:22 AM
blemoine02's Avatar
so a 3.73 with the stock locker because i all ready have on or what are you saying dont go with the stock get a eaton and i have 3.42 with 20 inch rims and low profile tires doenst that affect the gearing also should i still put the 3.73 with these rims and tires my radial are the same hight also <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jan 13, 2003 | 06:03 AM
2ksleeper's Avatar
If the limited slip you have is the G80 Gov-lock you shouldn't waist your time putting it in if you plan on doing a SC later. The G80 might work ok with a n/a motor but when you throw a SC or NOS on, it isn't worth a crap. I plan on putting 4:10's & an eaton aftermarket limited slip in mine in a month or two because I am tired of spinning one tire most of the time.
Old Jan 13, 2003 | 09:41 AM
blemoine02's Avatar
ok thanks so the limited slip doesnt really hold on hig horsepower motor your saying
Old Jan 13, 2003 | 11:47 AM
2ksleeper's Avatar
I am saying that the G80 Locking/Limited-Slip hybrid has crappy engagement. It takes a certain amount of wheel slippage between the two wheels to lock the differential down & if your wheel speed is above 25mph it wont lock down either. The differential locks down good on dirt or on wet pavement but absolutely stinks on dry pavement.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
moregrip
Jul 26, 2016 11:21 AM
StrokeTheLS
Sep 29, 2015 08:33 PM
Chevy305
Sep 28, 2015 09:21 PM
GM1697
Sep 28, 2015 08:28 PM
