lifters?
Old Nov 3, 2004 | 09:33 PM
mwalls54's Avatar
Need More N2O Mod
Default lifters?
i just colapsed a stock lifter. i am going to order a complete set from some where to with stand my cam, 216-220 56x-56x 116+4 i havn't really looked at them yet. just seeing what works best for people
Old Nov 4, 2004 | 10:26 AM
ktmrider's Avatar
Not too many options for lifters out there, if any. I did just read an ad for an updated LSx solid lifter design but nothing for hydraulic.
Old Nov 4, 2004 | 01:47 PM
ThunderZ28's Avatar
12 Second Club
Talk to thunder racing.
I ordered a set from them.,
I think I have the same problem you do
Old Nov 4, 2004 | 02:04 PM
marc_w's Avatar
You guys are runnng Comp grinds, right?
Old Nov 4, 2004 | 02:05 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
ok... I knew I was forgetting something...
Lifters. And rockers....
What are the limits on the stock stuff? I'll be pushing big boost on a 408 with a 230/236 600 lift 114lsa cam...
Old Nov 5, 2004 | 04:01 PM
BigKID's Avatar
I also have one that is bad. Just havent felt like pulling the head to change them. From what I have read, the stock GM lifters are as good as they get. :dunno:
BTW... which lifter/s let go on you guys? Mine is either in #5 or #7. Oh and I am running a FMS (cammotion) grind.
Old Nov 5, 2004 | 09:37 PM
mwalls54's Avatar
Need More N2O Mod
i ended up having two weak lifters i dont rem which ones they were. i went with stock lifters, had to drive 2 hours one way to find head gaskets though
Old Nov 5, 2004 | 10:09 PM
budhayes3's Avatar
PT's Slowest Truck
Is collapsing lifters a result of cam/spring swaps? Is the extra tension too much for the lifter? I'm getting a little paranoid with all of the ticky and tappy noises I seem to hear from my engine. Is this a common thing (the lifters, not the paranoia...I know that's common )?
Old Nov 7, 2004 | 07:34 PM
gully454's Avatar
depends on spring pressure. but if its a really big number it coulc be pushing it. the oil gets out of my lifters on my big block if it sits for a week or so, but thats because i am running 428 in/lbs springs
Old Nov 8, 2004 | 10:48 AM
budhayes3's Avatar
PT's Slowest Truck
So with the cam and springs in my sig, would you say that I'm more paranoid than anything else?
Sorry if I hijacked this thread.
