Lets talk Valve Springs. Experts please come in.
Old Jul 7, 2015 | 07:29 PM
07NBSChevy's Avatar
Whats everyones thoughts on the PAC 1904 or 1905 dual spring kits. Ive seen them around $280 with titanium retainers, hardened keeps and viton valve seals.
Old Jul 7, 2015 | 08:53 PM
06 4.8's Avatar
If going with duals go with the BTR .660 and be done. If they say your springs are good I would go with it though and not change them
Old Jul 7, 2015 | 09:19 PM
07NBSChevy's Avatar
I would like to just keep and LS6's and I've researched and seen a few people with same cam and LS6 springs with no problems. But I would hate to drop a valve so I'm a bit concerned lol. I have narrowed it down to 2 options if I don't keep to LS6's.
Pac-1218--Max Lift .600", 130 lbs @ 1.800", 318 @ 1.200", Coil Bind 1.140" Beehive Spring
Pac-1904--Max Lift .625", 155 lbs @ 1.780", 400 @ 1.130", Coil Bind 1.030" Dual Spring
Or maybe BTR .660's
Old Jul 7, 2015 | 09:30 PM
slick_sierra's Avatar
Default Lets talk Valve Springs. Experts please come in.
If you were running a tooley truck cam id say sure run the ls6s because they are what he sells with his cams and what he recommends since you're going with a Vinci cam with different lines than the tooley truck cams I'd go with a set of springs the cam builder recommends
Old Jul 7, 2015 | 10:27 PM
George C....'s Avatar
Formerly ScreamingL
I have the blue ls6/ls9 springs with
218/233 553/533 109 and been doing for last 13k miles
Think about that when thinking of your cam
Old Jul 7, 2015 | 11:20 PM
07NBSChevy's Avatar
So, Roger doesn't recommend single springs but he said the LS6 would be OK...But i did some research and the Vinci 080 Ultra Torque cam seems to be the same as Crane 1449051. Now crane recommends:
99831-16 Beehive Springs, Max Lift .600", 130 Lbs @ 1.800", 318 @ 1.200", Coil Bind at 1.140", now this seems to be identical to Pac 1218's
OR
144832-16 Dual Spring, Max Lift .650", 112 lbs @ 1.800", 352 lbs @ 1.150", Coil Bind at 1.045"
I read somewhere that crane recommends to not exceed the maximum closed pressure.
Old Jul 7, 2015 | 11:21 PM
07NBSChevy's Avatar
Thanks for your input. I am seeing more and more guys running bigger cams with Ls6 springs without issue.
Old Jul 7, 2015 | 11:30 PM
GMCtrk's Avatar
Don't forget correct install is every bit as important as the spring itself.
Choose a quality beehive spring and have at it. No need to over think it.
Old Jul 7, 2015 | 11:48 PM
07NBSChevy's Avatar
I'm just going to order the PAC 1218's they are cheap and will still have the longevity of the LS6's. So i guess i will selling 16 new Blue LS6 springs. Just be over it. I have been stressing this for a while now lol. PAC 1218's it is.
Old Jul 8, 2015 | 04:49 PM
bobfig's Avatar
im rinning the pac 1218s but i also on the stock cam. i would recommend reading up on installing them correctly.
also you can use the stock retainers with the pac 1218 as the place i took my heads did. there is a psi 1511 springs that are a tad more but they seem to be a slightly better spring. because they are nitrited.
watch this a few times
