Leaving some tread on the ground...
Old Dec 21, 2003 | 06:44 PM
02 Tahoe on 20s's Avatar
Default Leaving some tread on the ground...
Is there an easy "self mod" to let me be able to do brake stands? My car, even with traction control off cuts my throttle at 2000 ish rpm. It is quite aggervating. Thanks
Ben
Old Dec 21, 2003 | 07:11 PM
99Silver6.0's Avatar
Ah the dreaded effects of Torque Management. You either need LS1Edit or a Diablo to get rid of TM. My nod goes to Edit though. Getting a custom tune from Nelsons will get rid of it too.
Nelsons Performance
Old Dec 21, 2003 | 09:17 PM
Push the traction control button to turn off the traction control.There's not much you can do to really light up the tires on a Tahoe,the coil spring rear suspension provides much better traction than the pickup truck leaf springs.I've driven bone a stock G80 5.3 extended cab that has a lot worse traction problem than my supercharged Tahoe.
Old Dec 21, 2003 | 09:50 PM
well, the thing is that it just cuts the revs at 2 grand with traction off. Like i could be flooring it, and still nothing. it just wont let me go over 2 g. Whats the dilly? Thanks
Ben
Old Dec 21, 2003 | 10:52 PM
Tokez420's Avatar
get a stall
Old Dec 21, 2003 | 10:56 PM
Flyer's Avatar
Originally Posted by Tokez420
get a stall
What he said ....
A YAnk TT3000 should do the trick! It did horrible things for traction for me.
Old Dec 22, 2003 | 09:14 AM
marc_w's Avatar
The 2000rpm is probably just the factory stall. The engine is saying that's all I got.
With the extra weight on the back of an SUV, they're harder to get the tires to break loose.
Old Dec 23, 2003 | 10:33 AM
BigKID's Avatar
Is your hoe a drive by wire(electonic throttle body control)? If so that is probably your problem. Custom programming is the only solution that I know of.
Old Dec 23, 2003 | 07:33 PM
yes, my car is drive by wire. What about drive by wire makes the difference? Thanks
Ben
Old Dec 23, 2003 | 08:44 PM
Drive by wire gives the PCM more control over engine RPM's. Thus it can close the butterfly if it wants to.
