Lean at WOT, help
How do I change this text
Well I installed my third and last Nelson tune, tonight and the truck still is lean the top end. I KNOW it isn't the Tune, Allen has when far past the point of good customer service. I've check for vacuum leaks, and my fuel pressure goes up to 60 PSI at high idle, what else is there to check see sig, for all mods.
P.S. If ANYONE is thinking of getting a tune or tuner, I would recommend Nelson.
17,16,15,14,13,12,11 Drvr
have you had the injectors cleaned latley?? or the throttle body? changed plugs,wires? cleaned the air filter? wipe out the inside of intake tube? cleaned maf? fuel filter? just a few of the problems i have ran into with the trucks running lean on topend.
Originally Posted by JERRY2500
Did you change to an 02 PCM yet? I had all kind of problems with the 00 PCM. Running lean and false knock.
