Leaking oil--help please
Ok so i leave this morning and go do some yard work and go jet skiing damn that was cold but that is a hole nother story. so i got home about a 1/2 an hour ago and as i pull into the garage i see a puddle right dead center inbetween the wheels up front. at first i thought mabey the filter or plug b/c i just changed the oil last week. so i get the light out and look under there and oil is everywhere all over the skid plate up front, it had splattered oll over the exsaust and on back. plug looked good as well as the filter. it is dark here so i can't really see. but if anybody has an idea please help.
BTW it is down on oil but not all the way to add.
it is an ecsb 5.3 4x4 no motor mods
You should be fine if you are going to take care of it very soon. And it all depends on how much oil you are leaking. If you have to drive it make sure you keep checking the oil. But you should be fine.
