Largest header primaries that will fit?
Old Sep 27, 2015 | 05:03 PM
DrX's Avatar
DrX
Default Largest header primaries that will fit?
Anyone ever built/found a header with larger than 2" primaries that fit into a 99-06 truck. Is it even possible with stock motor mounts? Would prefer 2 1/4".
Old Sep 27, 2015 | 05:19 PM
thewrx's Avatar
6 bolt heads?
Think your looking at custom, but something that would require that kind of flow i would guess most **** is custom.
Old Sep 27, 2015 | 05:25 PM
03sierraslt's Avatar
What exactly is your exhaust set up from front to rear ?
Old Sep 27, 2015 | 05:29 PM
DrX's Avatar
DrX
Originally Posted by thewrx
6 bolt heads?
Yes 6 bolt heads and expect custom is the only option over 2". Just wondering if it is doable.
Old Sep 27, 2015 | 05:36 PM
DrX's Avatar
DrX
Currently ARH 1 7/8" to 3" full dual through FM Super 50s on the street. Midpipes are removable for the strip which leaves the merge collectors as the tightest bottleneck.
Old Sep 27, 2015 | 05:47 PM
Ever tested back pressure?
Old Sep 27, 2015 | 06:14 PM
DrX's Avatar
DrX
No, I'm mainly concerned with all out open header conditions.
Old Sep 27, 2015 | 11:41 PM
Blown06's Avatar
8 Second Truck Club
Over 2" is going to require a custom built header.
I'm considering doing this myself right now as well.
Old Sep 28, 2015 | 08:34 AM
DrX's Avatar
DrX
With motor plates, you have a lot more space to work with.
Old Sep 28, 2015 | 01:58 PM
sprayedenali's Avatar
has anyone ever tried a SBF header with LS flanges welded on..?
just a thought
