L92 Custom Cam/Cam selection
Old Apr 4, 2008 | 09:16 AM
OnyxSilveradoSS's Avatar
Default L92 Custom Cam/Cam selection
Hey guys, I am putting together a head/cam swap for my GM LQ9 6.0L and have been looking for a cam. I contacted livernois and they can give me either a custom cam or the one they have for the same price. I dont know enuff about cams to spec it my self...does anyone have a program or want to help me pick one??
6.0L
L92 head
Upgraded springs (.600)
A4
4.11 Gears-AWD
5600lbs
DD
stall undecided but should be between 2600-3K
Here are the few off the shelf grinds: the Livernois StageII
230/236 .590/.600 114
and carcraft's LS2 cam that put up 500hp thru a carb intake(compXR281HR)
228/230 .571/.573 112
Thanks for the help/tips/advise
-joe
Old Apr 4, 2008 | 09:52 AM
SS_bnoon_SS's Avatar
I'm no cam expert, but I just wanted to give you a stall recommendation for the Yank TT3000 stall. Drives almost like a normal SS until you put your foot past 1/2 to 3/4 throttle, even on the stock cam. HUGE thumbs up!!!
I'm getting ready for my L92 swap and I chose a custom grind of 231/236 591/601 114+4lsa, and I went with the carb style intake drilled for injectors. So I'd guess I'd choose the first one.
Old Apr 5, 2008 | 12:24 AM
Richard@WCCH's Avatar
FormerVendor
You'll be very happy with the Car Craft grind with your gear and converter choice. Remember, with L92 heads you can reduce the cam duration by 6-10º without losing the top end horsepower. Then the lower duration lobes will increase the average torque to the low and mid range rpms. Also the 112ºlsa will build a larger torque bubble than the 114ºlsa. Don't worry about the lower lift. The L92's flow well enough to not require lots of lift especially in truck or other high load applications.
Hope this helps.
Richard
Old Apr 5, 2008 | 09:04 AM
here is another
224/230 .581/.590 114
thanks Richard...very good info for helping me look at the cam #'s and compairing them better
Old Apr 5, 2008 | 11:11 PM
zippy's Avatar
That last cam may well be a good choice. With the big flow of the intake side on the L92's I wouldn't want a duration any bigger on the intake side than 224@.050 for what you're doing. Just my opinion.
Old Apr 6, 2008 | 09:30 PM
Thanks Zippy, been meaning to call but seems like I cannot talk on the phone w/o my kids deciding to go crazy.
They will custom grind one too, should I think about changing the specs any??
I get some conflicting info not to mention people are super crazy about giving out L92 cam specs.
Old Apr 16, 2008 | 11:18 AM
considering running the cam I have in there now:
224/224 .581/.582 112
I will run LT headers also.
Anyone know which is better with L92 heads no overlap or little??
Old Apr 16, 2008 | 10:06 PM
xdanny510x's Avatar
i got a 230/244/114lsa on mine
Old Apr 23, 2008 | 08:45 PM
well I am getting the smaller one:
It was designed with 6.0L in mind and alot of guys who run a few cams say the smaller the better with little loss of power. I will keep all the L92 eyes posted
Old Apr 23, 2008 | 09:10 PM
zippy's Avatar
That cam is a bit heavier on the intake duration for what you're doing, but all in all it should work out well. Which intake manifold are you going to use?
