KR problem!
Old Jul 17, 2005 | 10:00 PM
Bradazz's Avatar
Default KR problem!
I just scanned my truck and it shows that right after my truck shifts into second gear that it has 7 deg. of KR which I know is not good. I have checked for noises and I cant find anything wrong. Any help would be great. Thanks, Brad
Old Jul 17, 2005 | 11:58 PM
TXsilverado's Avatar
maybe it will go away with some better gas. if not call your tuner
Old Jul 18, 2005 | 06:31 AM
JERRY2500's Avatar
14 Second Truck Club
Are you still useing the 00 PCM? If so, Switch to an 02 PCM and this will solve the kr issue. 99-00 PCM's are known for false knock issues.
Old Jul 18, 2005 | 07:25 AM
Ruffrider5.3's Avatar
Do you hear any detonation? I know my 98 Z28 used to get false knock due to loud as hell exhaust. Do like he said and run some good gas and I know some tuners desensitize them which is a no no.
Old Jul 18, 2005 | 09:20 AM
Bradazz's Avatar
Thanks for the replys, I do not think it is the gas because I only use Marathon 93 octane. I am thinking the problem is the pcm, I am in the process of getting a Brand New 2002 pcm and hopefully that will fix my problems.
Old Jul 18, 2005 | 09:27 AM
Bradazz's Avatar
If I change to a 2002 pcm will I have to change the fuel injectors?
Old Jul 18, 2005 | 09:34 AM
JERRY2500's Avatar
No, they will be fine.
Old Jul 18, 2005 | 09:45 AM
Z284thgen's Avatar
11 Second Club
soon as i did the cam install and springs on mine it started pulling KR and i was like wtf
during tunning we starting turning the KR down and never heard and detonation on it so we left it pulling at least 2* until i can figure it out
so does any one know more info on the 99-00 pcm's and why they do that
Old Jul 18, 2005 | 09:57 AM
JERRY2500's Avatar
The only problem I had is the flashing battery light and dtc code "Generator Terminal F circuit". But your tuner can diable this code. or you can do this https://www.performancetrucks.net/fo...ight=generator
Old Jul 18, 2005 | 04:37 PM
Bradazz's Avatar
I just thought I would post my scan (below) when I noticed the knock retard even though I figured out what the problem is. Thanks
Scan
