knox sensors
Old Dec 28, 2006 | 12:43 PM
getchusum99's Avatar
Default knox sensors
are the located under the lower intake? i have a 5.3. how much of a pain are they to change?
also at what point in the year model does gm change there year model in vehicles. for instance my truck was biult in 10/99 so would that make it a 00' or a 99' . i know that all ford vehichles after the 6th month are considerd teh next year model. im asking this because of my stock pcm. or how can i tell by my vin#??
Old Dec 28, 2006 | 01:32 PM
bigbadwolf54's Avatar
13 Second Truck Club
The knock sensors are under the intake, I can do them in under an hour if I'm in a hurry. The 10th digit of your VIN is the year, 10/99 will probably be a 2000 yr model with a 10th digit of Y.
Old Dec 28, 2006 | 03:28 PM
Thanks Man Ill Check When I Get Off Work Today.
DO YOU HAVE AN IDEA OF HOW MUCH THE SENSORS RUN? THERE ARE 2 RIGHT?
Old Dec 28, 2006 | 04:26 PM
yeah 2 sensors and if you're changing them because they've gotten wet [TSB out for that] you might wanna get a harness for them too. I think they run around $60/each from GM and the harness I think was around $20.
Old Dec 28, 2006 | 04:33 PM
thunder550's Avatar
High on diesel fumes
Sounds about right to me.
Derek @ EDO's Avatar
FormerVendor
you can get them from auto zone, i think they are 40.00 a piece
Old Dec 29, 2006 | 07:51 AM
Would It Be Better To Get The Gm Ones Or Autozone? And No They Didnt Get Wet But ,they Have 215k On Them And My Timing Is Being Robbed Bad On Low End, I Mean Bad! So Before I Go To Get My Tune Fixed Id Rather Be Safe Than Sorry And Put Some New Ones In. The 99-00' Trucks Had False Knock Problems Right?
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
Wrecker 426
Sep 30, 2015 09:39 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
